How to extract stress values at different nodes from .odb files
I have some .odb files which gives some results in the form of stress field.
How to extract stress values at different nodes from .odb files??
RE: How to extract stress values at different nodes from .odb files
If you want toe extract output from multiple nodes/elements, you can use Report -> Field Output in Abaqus/Viewer. This allows you to report field output (like stresses/strains etc.) to a text file that's saved in the working directory. Results are written for whatever nodes/elements are currently visible in the viewport. Ideally, you would have your nodes/elements that you're interested in saved in specific node/element sets for this purpose.
This is all described in the manual:
Abaqus/CAE Users Guide: Part V: Viewing Results
