Aftermarket manufacturing
When a replacement part is manufactured, I bet it is not redesigned. Rather copied. Isn't this some form of infringement? Do aftermarket part manufacturers pay royalty to OEM?
Aftermarket manufacturingAftermarket manufacturing(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Aftermarket manufacturing
As for copying (often inferior) ... good luck getting certain other countries in the world to respect intellectual property rights.
Mike Halloran
Pembroke Pines, FL, USA
Take a Diesel engine cylinder liner (industrial engine). This is a part often replaced as a spare since they are often not recoverable following wear.
The engine manufacturer has a choice, bind the component supplier into a deal to have exclusive use of the component, or a deal where the component supplier can supply spare parts unbranded. The component supplier does the second option at a lower price to the manufacturer, so the supplier can have direct access to the lucrative spares market.
Keith Cress
In the UK, the Ford OE clutches, the Ford aftermarket clutches (Motorcraft possibly, they were marked FoMoCo) and complete aftermarket clutches for the Fiesta (I think, maybe Ka, possibly the Focus) are all made on the same production line, using exactly the same pressings, castings, etc. Just to different quality specifications depending on their final use.
I once owned a 1977 Oldsmobile from 1985 until 2008 that had 350,000 miles on it before I gave it away (running) to the son of a friend who drove it for two more years (after that, the engine/transmission was pulled and placed into a lawncare pickup work truck and used one more year until the vehicle was wrecked). While I owned it I did all the maintenance. There were suspension parts and things like radiators, fuel pumps, alternators and the like that I replace many times. There were things like ball joints that I replaced when they got around 20 years old. The rubber boots were in bad shape, but had not split. The boots that came with the non-OEM replacement ball joints disintegrated within a year !!! I replace the ball joints a second time just because of this. The next set of ball joints wore and became too loose in 5 more years, so I replaced them a third time. There were similar issue with many other parts including non-OEM radiators that had a tendency to only last 2 years.
I replaced that car with a Saturn and experienced similar replacement parts issues. Now I drive an Acura and only buy OEM parts.
not a choice of 1 year guarantee or lifetime as is common.
We installed them in place of the ~ 150 kmile originals, carefully torquing the bolts and deformed thread locknuts used in place of the OEM rivets.
He was doing something under the truck about a year later and noticed the boots were deeply cracked, and one of the 4 retaining bolts was missing, almost certainly having broken.
This is much, much more common than the alternative.
There are not 400 different plants in the world that make ball joints- there are a few. Same goes with clutches, or brake cylinders, or brake rotors, or whatever other highly automotive-specific part you can think of.
For something that is used in a car or truck but is common in other machines or industrial equipment- such as shafting inside a transmission, or gears used in transmissions and steering equipment, etc, there may be many sources. But a lot of parts used in cars are bought in VERY high volume and aren't widely used anywhere other than automotive; for these parts there are not an infinite number of sources.
For ball joints, for example, ZF is a major player and they sell to every OEM there is. So not only are the Ford OEM ball joints made by ZF on the line right next to the Motorcraft branded replacements, they are often made on the same line or 10 feet away on a slightly different line as ball joints for Toyota or Honda or GM or Fiat or whomever.
Cheers
Greg Locock
I had the need to replace some wheel bearings on a Ford last summer, and thought I was doing the right thing by going with the more expensive and better-known 3rd party supplier. I had one fail within 2000 miles. When I ordered a replacement, the new part arrived incomplete (missing a sensor) which I set about to transfer from the failed unit - only to then discover that the manufacturers' marks were completely different on the two supposedly-identical units. Further internet searching revealed that the second unit more closely matched the lower-price aftermarket units than the higher-priced one, although the packaging had clearly been for the higher-priced one. Another curiosity was that the lower-price one had branding marks on the subcomponents from recognized suppliers (Timken bearings for example) whereas the higher-priced one had none (perhaps due to contract, perhaps due to differences in the supply base). Anyway, I sent 'em both back and the third bearing received matched the first & hasn't failed yet.
What "sigma" is that ?
