Integral reversal flange calcs
Code: ASME VIII DIV.I
I have this vessel, with a shell made from pipe, which has at the top and at the bottom welded two integral reverse flange.
I verify this flanges acc. to appendix 2 and they pass the calcs. Question: do I need to do other verifications? For example, considering them as flat head with openings....or is it enough what I've done acc. to appendix 2? thanks
RE: Integral reversal flange calcs
Mike
