Turn of the nut method with an impact gun?
I am currently working on a bridge that has slip critical connections. The bolts need to be pre-tensioned to about 170kN. The method chosen to pretension the bolts was the turn of the nut method, using a 1/3 turn. I am having some issues with the contractor in achieving this third of a turn. It was originally thought that the contractor would snug tight the bolts and then extend the lever arm of a wrench with a piece of steel pipe or something to turn the nut a 1/3 of the way. The contractor is stating that there will not be enough space under the bridge to use an ~ 4' lever arm. Fair enough... due to the lack of space I told the contractor to use an impact gun to snug tight the bolt and also use an impact gun to turn the bolt a third of a turn. They originally used a 3/4 impact gun, however, it only turned the nut about 1/4 turn.
They used this gun : http://www.ingersollrandproducts.com/content/ir-pr...
I told them to use a more powerful 1" air impact gun. I was under the impression that impact guns can actually break bolts. So will a more powerful 1" air impact gun get at least a 1/3 turn?
BTW they are using 20mm diameter A325 bolts that are 80mm long if that makes any difference.
Any help or advice with methodology would be greatly appreciated.
RE: Turn of the nut method with an impact gun?
Dik
Thanks for the fast response. Yea they are chalking the nut and bolt to check for the 1/3 turn. It is just that the impact gun they were using was not getting the 1/3 turn. The methodology was as follows :
- Give a hit of the impact gun to snug tight the bolt.
- Mark the bolt and nut with chalk.
- Use the impact gun to turn the bolt to the required 1/3 turn.
With regard to adding a bar to increase the lever arm, that wasn't to be added to the impact wrench, it would've been added to a normal spud wrench or torque wrench if they were going to turn the nut by hand.
AISC Specification for High Strength Bolts (2009) defines snug tight as "Snug-Tightened Joints
All bolt holes shall be aligned to permit insertion of the bolts without undue
damage to the threads. Bolts shall be placed in all holes with washers positioned
as required in Section 6.1 and nuts threaded to complete the assembly.
Compacting the joint to the snug-tight condition shall progress systematically
from the most rigid part of the joint. Snug tight is the condition that exists when
all of the plies in a connection have been pulled into firm contact by the bolts in
the joint and all of the bolts in the joint have been tightened sufficiently to
prevent the removal of the nuts without the use of a wrench"
Perhaps the impact wrench tightened more than this on the initial install?
Also keep in mind AISC requires more or less turns of but to achieve pre tensioned limit based on length of bolt. I'm not sure if AASHTO has similar requirements or not. See Table 8.2 of document referenced. The turns vary between 1/3 to 1 full rotation depending on bolt length.
The quote provided by jdgengineer above suggests that a compliant procedure would involve spinning the nut on manually until the resisting torque starts to rise, then chalking the nut and using the impact gun. ... but nobody wants to do anything manually these days.
My own experience says using the impact gun to spin the nut on will give somewhat inconsistent results. Perhaps better to spin it on with a battery powered drill or screwdriver, especially one that has a torque limiting clutch, then switching to the impact gun.
Mike Halloran
Pembroke Pines, FL, USA
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
https://www.facebook.com/AmericanConcrete/
Further, the commentary in that document states "The snug tightened condition is typically achieved with a few impacts of an impact wrench, application of an electric torque wrench until the wrench begins to slow or the full effort of a worker on an ordinary spud wrench."
This is all subjective and depends a lot on field variables. I'm much more a fan of quantitative measurements using a torque wrench calibrated to bolts in a Skidmore-Wilhelm device or direct tension indicators whether load indicating washers or Tension Controlled (TC) bolts.
Yes snug tight in the code is quite subjective. To snug tight the bolts I had the contractor do only one hit with the impact wrench. I got one of the iron workers to see if he can turn it after that hit with a normal spud wrench. He wasn't really able to turn it much more by hand. The impact gun was getting it to turn about 1/4 of a turn (Which the iron worker perhaps could've done by hand with some serious effort).
This leads me to think that the impact gun being used had the same strength as an iron worker using a 14" spud wrench. Therefore not heavy duty enough to stretch the threads? Or am I wrong in this logic?
I assume that the worse case scenario would be that the bolt would just break - but would also assume that a heavy duty impact wrench can break a bolt. A 1/3 of a turn is really not that much considering it is the lowest turn used in the turn of the nut method.
They were using a 3/4 air wrench : http://www.ingersollrandproducts.com/content/ir-pr...
Most sources do not recommend using a calibrated torque wrench. Measured torque has too great a variation.
DTI washers work really well.
A few trials would help understand how important and variable the initial "snug" is.
This is correct almost all of the time in the automotive world.
The caveat to that is that in the automotive world, you have a very high level of control over the conditions of a joint- parts are typically very flat/parallel, well machined, everything is clean and lubricated consistently, and at a consistent temperature.
I would suspect that in bridge building there is a lot more variation in the condition of parts, fasteners, temperature, etc etc.
The truth is ugly- but you don't. If the bolt head isn't moving you aren't really checking bolt preload.
Dave
Thaidavid
another power wrench i've seen allows you to set the amount of turn from 1/4 to 1/2. theoretically you send someone through just to get snug and then the 2nd guy finishes it
but, definitely have done TON method with impact wrench quite a few times, but usually moment connections in simple buildings
Stock values on a standard torque chart are, sure. For automotive components, the lubrication is designed in and the torque specified in the manual is specified with that lubrication in mind. Some fasteners are lubricated, and some are not, depending on the application.
I like it.
