Pig receiver - Steam out?
Hello everyone,
Is there any standard about the pig receivers regarding weather to consider a steam out condition and nozzle or not?
(length:12010 mm, OD: 30 in, lethal service, operating pressure: 127.2 barg and operating temperature: 35/52 C)
Thanks!
Thanks!
RE: Pig receiver - Steam out?
Cheers, gr2vessels
To the main subject I don't know if piping is normally or even ever designed for steamout but I'd guess the piping design conditions would be the guide for the pig receiver.
Mike
I'm not sure of your position or role in this item but so far
1) You're designing it to the wrong code (IMHO)
2) You don't seem to be aware of the Design pressure or test pressure , only the "operating pressure"
3) you don't seem to have the P & ID or access to the process engineer where this should be determined
4) I don't know what this stuff is other than "lethal" service so can't say whether you need to use steam to make the contents of the trap non hazardous when you open it ( which is the whole purpose of a pig trap).
As a designer these are all things you should know.
There is no "standard" as this sort of requirement depends on the contents and their hazard to an operator. I've seen purge and vent nozzles before now which is required in some instance and overkill in others.
If it needs steam then this becomes a low pressure, but high temperature event which needs to be allowed for in the design and suitable precautions to prevent over pressure with high temperature steam.
I am not the only designer in this project. For your information I have access to all information related to this project. However, the head of eng. group has asked me to redesign this equipment assuming a pressure vessel rather than a pipleline component. I might be a new member to industry but I am aware of the minimum requirements to start designing. If my questions are so easy in your perspective just be nice and answer them humbly or do not even open my posts. Thank you for your replies anyway.
Next time be a bit more upfront and state what you have just stated in the last response.
There are a lot of posts here from people that clearly don't have a clue what they're doing and are trying to design it off the internet - if you don't tell us information that is pertinent to the question then we don't know.
If you had access to all the information why were you asking about design pressure and test pressure??
Glad to be of help.
