Proportional control valves - solenoid operated – cetop 03 - WHAT TYPE OF DOUBLE VALVE CONNECTOR?
I'm trying to find a double connector [form A(18mm)] for proportional valve (0-2500mA PWM signal).
As I understand I can't use one with any kind of suppression fitted inside (i.e.Z-diode). What about LED diode?
If anyone knows a manufacturer (or even part number) for this type of connectors it would be very helpful.
David
David
