Mass flowrate calculation through a cold plate
Folks:
I'm trying to recall from my thermo how to figure the flow rate required through a cold plate? If I know the temperature rise and the heat dissipation, isn't it just mdot=Q/(cpΔT)?
Thanks!
Thanks!
Tunalover
RE: Mass flowrate calculation through a cold plate
Q = area* k * delta_T / thickness
TTFN (ta ta for now)
The 1D heat equation you provided is not relevant to what I need to know (you also have the sign wrong). I know how much heat (in Watts) the liquid coolant carries away and I just want to calculate the required mass flow rate. I know the temperatures at the inlet and outlet so I know the coolant temperature rise. I also know the specific heat of the coolant. So I think it might be this simple but it's been so long since I did any thermodynamics or heat transfer calculations involving moving fluids that I'm a bet pensive on the subject.
Tunalover
