how to empty detention pond thru gravity if outfall is higher elevation
how to empty detention pond thru gravity if outfall is at higher elevation?
RE: how to empty detention pond thru gravity if outfall is higher elevation
pipe through the berm is the most common way, typically with a concrete structure within the pond to control the flow from the different design storms (i.e. 1-yr, 10-yr, 100-yr storms). what jurisdiction (country/state) is the project located?
