Waterproofing CIP Box Culvert Joints?
Hey everyone, I'd like to get a feel for typical waterproofing details that are used for construction joints on CIP box culverts. I am wrapping up a design on a twin barrel CIP reinforced concrete box culvert that will be constructed in two stages (i.e. there is a construction joint the full perimeter of the box section splitting the box into two halves). This is being done to stage construction. Additionally, there are the typical construction joints between the floor slab/walls and walls/roof slab. I've seen several details now ranging from nothing, to internal PVC waterstops, to blueskin being applied externally, to a combination. Example, see this one below.
A colleague asked me why even bother placing a waterproofing membrane on the exterior of the joints at all seeing as the culvert is flowing full of water anyways. It got me thinking, what would be the purpose and why have I seen it many times before? One can argue it is to prevent soils from washing in but that would require quite an opening of the joint. Any thoughts on the matter?
RE: Waterproofing CIP Box Culvert Joints?
Structurally, a waterstop can also prevent intrusion of water into the joint and corroding the rebar but you would need 2 waterstops. A bentonite waterstop on each face of the wall would work.
Often use blueskin for electrical vaults. Another good product is BlueStuf by Penkote...
Dik
