Acoustic Resonator damping capacity
Can someone help me to explain about acoustic resonator damping capacity?
As per my understanding, damping capacity is the ability of the material/system to absorb any incoming energy (i.e. mechanical energy) into heat.
Hence, if some acoustic resonator (example, Helmholtz resonator) having a high damping capacity, it means that the pressure amplification ratio of it is low?
Do you have any related reading material that explicitly explain about this concept?
Any help/explanation in order for me to understand about this concept is greatly appreciated.
