PLC, contactor and wiring migrate/upgrading advice
I am new in project engineering and my previous work is PLC programming only. For experienced engineers, what are the step by step procedure that you use in migrating/upgrading and what are the things that I will avoid?
RE: PLC, contactor and wiring migrate/upgrading advice
This has been discussed several times to great extent in here. It will help you formulate a more specific question(s) and further your knowledge.
Keith Cress
You should have everything written and bench tested before you make any attempt at changing out the existing system. Have a written plan for field testing. Don't burn your bridges. If you start taking things apart without a plan, life will become painful quickly.
EE
