How wheel load is distributed on a slab under soil?
RE: How wheel load is distributed on a slab under soil?
Based on AASHTO's load distribution through soil cover I calculate a distribution width of 1.37 m by 1.37 m which results in a distributed load of 53 kN/m2.
Professional Engineer (ME, NH, MA) Structural Engineer (IL)
American Concrete Industries
www.americanconcrete.com
Are you using LFD or LRFD? Also what is your tire width? I believe those factor into the distribution.
Yeah, I assumed a 10 inch by 10 inch tire contact area.
Big difference between the Boussinesq and Westergaard solutions in Example 6.2 (11.43 vs 7.25 psf).
BA
Per AASHTO, Its the tire contact area increased by 1.15 times the depth of fill. If you have overlapping wheels, it would increase. Im getting around 70Kn/m
