The interaction property "Default" !!
Hi every one
After simulation of Contact problem regarding to COHESIVE BEHAVIOR i have received a message in Note box in Abaqus :
The interaction property "COHESIVE_LAYOR" has been created
The interaction "general_contact" has been created.
The interaction property "Default" has been created.
in my case There are only 2 surfaces ,which are defined with "COHESIVE_LAYER" property and no other surfaces ,which are located in contact .
the question is ,why should has been created the interaction property "Default" ,although no other in contact located surfaces exist at all??
F.Danesh
