Support ring for Packing inside vertical vessel
I need to design a ring supporting packing inside a vertical vessel, I have started with Roark's formula for stress and strain but confused which case i should consider.
I would like to know if there is any other approach.
RE: Support ring for Packing inside vertical vessel
Steve.sw90, I would expect the usual pressure vessel handbooks address this feature.
Mike
Depending on your geometry, it may be multiple load cases superimposed, or may not fit any of the load cases.
See Pressure Vessel Design Manual 4th Ed. Dennis R. Moss and Michael Basic.
r6155
r6155, I HAVE 3RD EDITION COULD YOU PROVIDE ME WITH REFERENCE PARTICULARLY RELATED TO MY REQUIREMENT
