Move object in NX by matrix
Hi all
I am trying to find out how to rotate/translate a feature of a part by a 4x4 matrix related to a specific csys in NX 10.
The matrix comes from another program.
I already tried move object as well as adapting the code provided in http://www.eng-tips.com/viewthread.cfm?qid=354338, but couldn't get a usable result.
Any ideas? ponder
Thanks!
RE: Move object in NX by matrix
As far as i know there is no way of entering transformation matrices directly in NX for use in parametric modeling.
This is how I would do it interactively,
  1. Create an offset csys with the specified source csys as reference.
  2. Extract the translation, and rotations from the 4 x 4 matrix by hand or via expressions if im going to change it alot.
  3. Make sure the offset csys is associative and press ok.
  4. Then use move object, disable preview (move object is among the slowest commands in NX) select the bodies to move, choose csys to csys as method and choose the source and target csys.
  5. Select Associative under settings, press preview or ok.
Hi petulf
Thanks for your suggestion, it worked quite well
However, I still have one problem: Is there any command where I can define the order of rotations when offsetting the csys?
no, but you can create a chain of offset csys. Where each csys only performs one rotation.
That's what I've done now. Thanks for your help! =)
