Dimensioning Multiple Unique Holes
I have a quick question that I can't seem to find an answer to by searching around in the usual spots - however to be fair I haven't poured over ASME Y14.5 or similar GDnT documentation/standards.
I do quite a bit of fixture plate design for use in a CNC mill and they are often filled with quite a few holes of varying size/depth. More times than not, several of these holes are very close in size, sometimes within a few thousandths so they aren't necessarily easily visually discernible as different if I were to put 3x "X" dimension/depth and 2x "Y" dimension/depth and so on. I have my own ideas about what I could do to group these together short of dimensioning every single hole individually, however I am wondering if anyone out there might have a suggestion, maybe from their own best practices or a drawing standard. I do not necessarily need to conform to a strict standard, I really just need something that is visually neat/organized.
I have attached a sample (blank) plate which I will have to create a drawing for.
RE: Dimensioning Multiple Unique Holes
A hole chart might be the cleanest way.
John H. Dunten, CD
Certified Drafter
I have actually been banned from using hole tables. This is unfortunate, since the machine shops like them, and DraftingMan is correct.
I am on SolidWorks here. If I have two sets of similar holes, I sometimes open the Insert, Annotations, and I place the dowel pin symbol on one set of holes. On 3D CAD, you can show multiple instances of the same view, and use each one for one set of holes, only. This is bad practice on a drafting board, but hopefully, you are not on a drafting board.
If you are on a board or on dumb 2D CAD, you can methodically draw one set of holes out of scale. The ASME AY14.5 standard requires you to underline not-to-scale dimensions. It would be helpful to leave a prominent note warning that you did this. In 3D CAD, the model is accessed separate from the drawing, so that practice is unacceptable.
JHG
We will sometimes end up with holes of the same size but different depths (e.g. in some areas they are .XX min full thread while in others they are just 'thru') or just holes of different sizes etc. that aren't obviously different.
In these cases I'll leave one set blank, and then annotate the others with a letter e.g. X and then for the call out put "HOLES INDICATED X".
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
KENAT/AndrewTT - thats along the lines of what I was thinking, I just didn't know if there was more universally accepted way of doing it. I like the "INDICATED X" notation.
This should suffice if I don't have an exorbitant amount of holes - otherwise I might resort to a hole chart similar to what was mentioned.
drawoh - whats the reason you were banned from using hole charts? is there some disadvantage to their use or standards to which they do not conform?
They want consistency.
JHG
Years ago the checkers wouldn't let reference trimetrics to be used on drawings. First, on the claim that it was redundant with the rest of the drawing and second, that if the CAD generated drawing needed to be updated by hand, it might be difficult to do.
IOW - consistency.
How many years ago? I have actually been handed plots that were done in eraseable ink. This allowed me to update the prints on a drafting board. I have no problems with reference dimensions now.
JHG
It's been a while. The plots were ink on mylar - the checkers were thinking the drafters couldn't do the trimetric geometry updates or get a new version to trace. The sick part was that it took less time to replot the drawings than to get the drawing from the vault, et al.**
It's funny all the rules that -had- to be followed about drawing scale and such; now people print E-size drawings on B-Size paper and that's OK, but when CAD started out, people would freak at a 2/3 scale.
**Best ink/plastic lead-on-mylar story: There was a project that was in production and going along and a non-CAD drawing needed an update. So drafting sends for the original from the vault. It comes up and is a repro. Some program manager on another project wanted a derivative product so they ran repros of the originals, and put the repros back because the originals were easier to alter - they scrubbed the signatures and revision history and drawing numbers from the originals. The repros were the ones you need to use erasing fluid to alter. And no, the other program manager didn't mention his plan in advance.
I've had CAD monkeys do the same to CAD models; go into the PDM system and rename them to keep the relationships and save-out a copy under the original name.
Putting the copy back in the file and renumbering and renaming the original makes a lot of sense to me, much of the time. Presumably, the new drawing is the latest version, and you plan to keep updating it. It ought to be easier to modify.
I was in charge of our original CAD network. People copying out to make changes worried me. I made it clear that files were to be edited in place, unless they were doing something new. When they screwed up the existing files, I was polite and friendly as I recovered them from the backup.
JHG
