Weld size in pressure vessel
Hi, we're designing a pressure vessel and after performing the calculations there is one part that with 8 mm thickness is enough (corrosion allowance already included). Going to the next standard plate of 10 mm the weld thickness (two sides) is 0.7·10 = 7 mm which we can make in a single layer.
In this Project we have many parts in 15 mm thickness so we've decided to standarize thicknesses to 15 mm also for the part of 10 mm.
Now my doubt is, the welding of that part should be based of the nominal thickness of 15 mm(10.5 mm) or can I make it based on the mínimum required thickness?
All the standard seem to be based on nominal thickness but this would be overwelding a lot.
Best regards.
Best regards.
RE: Weld size in pressure vessel
But the Euro convention is to size fillet welds by throat dim, which is approximately .7 x 10 mm. (0.707 in a CAD world.)
Simple, really.
Mike
General Blr. CA,USA
