Completeness of a drawing
How complete does a drawing have to be and what is the general practice in the age of CAD? In many cases, I end up sending CAD files to the manufacturer and maybe just mark critical tolerances on the drawing with a general tolerance for unspecified dimensions. However, when this part comes in for inspection, the inspector might want to inspect even the dimensions left unspecified on the drawing - at least for the first time to qualify a new vendor for example.
Should I always strive to make the drawing complete to appease both sides and just highlight/mark critical dimensions? This might become unfeasible for complex parts. If I dont, the process of putting dimensions on the drawing becomes highly subjective - like one might want to put dimensions not not obviously critical on there to inspect to in the off chance that the vendor doesnt hit his general tolerance number.
RE: Completeness of a drawing
Inspection is a job.
One of the things that a drawing must do is define how to perform an inspection.
I also urge you to reconsider what you mean by 'critical dimensions' - again this has been discussed before with varying view points given.
Suggest you use the search button in the silver ribbon bar, not the google search.
thread1103-420134: Sending out RFQ 2D Drawings v 3D Models was a recent example.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Here is another interesting discussion: thread1103-322065: Critical Dimension.
I don't want to mark critical dimensions on my drawings. There are two conditions that require close attention from inspectors...
- The feature is critical for the functioning of the component.
- The feature is difficult to fabricate accurately enough. We expect production to fail frequently, and we need a lot of inspection, and we expect to scrap or re-work components.
The fun starts when both conditions are true.--
JHG
Mike Halloran
Pembroke Pines, FL, USA
