I cant see the Bend up lines in a flat pattern drawing
Hi All
My problem is that I cant see the Bend up bend down lines when I have a flat pattern in my drawing.
I have looked in the customer defaults and they are enabled, all layers are visible, nothing Is hided.
What am I doing wrong
I working in NX 8
RE: I cant see the Bend up lines in a flat pattern drawing
Try changing the reference set of your part in the drawing to "entire part".
That's worked for me before.
"It is impossible to make anything foolproof because fools are so ingenious."
Hi DonNX
I tried that, and it didn't work. Got mad, deletet the drawing, and the flat pattern feature in the model and started all over. Et voila it worked. I think it was an error 16,( 16 inched away from the keyboard), I have have probably used solid pattern instead
Thank for you time
Br
trkpofir
No problem, it happens to the best of us winky smile
