I have a situation where a SUB-Asse
I have a situation where a SUB-Assembly (supplier provided) needs to be shown in 2 different positions. If I owned the assy. I could use arrangements but now I am thinking of linked body but I can't suppress it with arrangement. I thought of suppress the constraints but can't reach into the supplies part...
OK so the question is "how do I show the components in 2 different config even thought I do not own it?"
Please be gentle as I should know but...
Cj Silver
Cj Silver
Tooling Engineer
yesterday was... today is ... tomorrow MAYBE?
RE: I have a situation where a SUB-Asse
The "over-ride position" function may do what you need. I very rarely use it, so I don't remember how it works with arrangements...
www.nxjournaling.com
I will try that but imagine all the wire ties need to be moved from right to left side...you can see where mirror doesn't work...
Cj Silver
Tooling Engineer
Live everyday like no one is watching...
So this is a mirrored part/assmebly? I don't see that mentioned in the first post. Perhaps you can elaborate on your situation?
can you create a new assembly above the current top level and in there use arrangements ?
Tomas
