Spline help - error in interaction with hub
Hi all,
First time post here so go easy on me!
I have an issue with a current build I'm working on. There was a CAD error which has resulted in hubs being manufactured with an identical spline form to the driveshaft. Obviously this has resulted in a transition fit and thus making the 2 parts not viable to fit together. What options do I have? Can I get an oversized broaching tool made to clean out the excess material? So far possible resolutions are;
1. Try to use current driveshaft as the broaching tool, creating a lead in to aid location
2. Heating and freezing mating components (very difficult to do as bearing is located right next to the splined area and will likely distort
3. Looking at a tool to individually remove material from each tooth
Any suggestions? Need to do something asap! The hub is EN16T and at this point I'm not sure on the driveshaft material. Any help would be appreciated.
RE: Spline help - error in interaction with hub
Spline data, drawings, material/heat treatment specs and parts quantity.
If so see if you can find someone to slurry (ExtrudeHone) hone it.
This should be able to take out enough material for a fit without changing the profile much.
My friend Fred used to accurize M1911s by squeezing the slides in a vise so they were a little tight, then assemble them with non-fluoride toothpaste, and run them back and forth by hand until they loosened up just a tad. Of course, he only did one at a time, and didn't really care about the uncertain number of hours of hand labor involved.
Mike Halloran
Pembroke Pines, FL, USA
Due to tooth-tooth spacing errors as well as profile error; the transition fit you describe is more than likely going to be an interference-type fit for the majority of the contact.
Also, the flanks are not going to be the only point of contact. The major & minor diameters will also be making contact.
You still haven't told us the heat treatment & material specs or the quantities involved.
We also need to know how these parts were manufactured.
We also need to know how these parts were manufactured - As above, machined from solid. Driveshaft from GKN I cant get hold of the tech specs yet.
I have 12 in this condition. I agree with the interference fit. The spline was cut using EDM, would I have any chance going to the supplier and seeing if they can reset the pieces and re cut?
Getting the parts set up again is going to be a bit painful, but may be the most predictable outcome. At least with EDM you won't have tool deflection. I expect it to cost a bit more than the first go around as the entire surface has to be recut, plus it has to match the location and orientation close enough not to be cutting 'air' which will leave mis-matches. Other than that it's up to the skill of the EDM operator.
It may be the parts are close enough that crocus cloth and a power file setup would polish the part to fit, but there is less control and getting the fit uniform will not be guaranteed. You could make a tooth=shaped support for the crocus cloth to try to maintain the shape, but it's tough to create root clearance that way.
The match-polish method is OK, but it also will alter the shaft spline so any replacement with a correct hub won't fit quite right. I don't know if that's a problem, but it should be noted in the as-built list if that's what is done so any future repairs aren't mystery items about unexpected clearance.
I think the extrude hone won't be the best solution as it tends to smooth off the high shear points, which won't be in the recesses. I expect it would open up the tip diameter and round the tips but not help with the sides or the root fit. If it was cylindrical extrude honing would be a good answer.
Best of luck.
I think the parts can be masked, e.g. with a strippable coating, so the electrolyte only touches the splines.
I think the electropolisher will have to make an electrode, basically a slightly undersize mating part.
At some point you are better off painting the mere dozen parts purple and mounting them on nice walnut plaques to give away as desk ornaments.
Mike Halloran
I have spline info for the hub and shaft,
Hub
[url=https://postimg.org/image/ks86hkavb/]
Shaft
[url=https://postimg.org/image/k2t5ku1s1/]
I have been in touch with a few spark erodes who believe they will be able to do it without too much trouble so that's the route I will probably take.
The spec is calling for a lead correction of 32', +/- 4'.
I don't know of an EDM that could replicate that, let alone applying it to a profile which has, no doubt, already been machined without the correction.
