Welder Qualifiication as per section 452
Dear sir,
I want to know that, as per sub section 452.1 (B) of ASME Sec IX, what the "All" refer.
Pls find the attched file.
Prasad Rode
Prasad Rode
RE: Welder Qualifiication as per section 452
For weld thickness of 1/2" with less than three layers allows a qualification range of 2t
Weld thickness of 1/2" with three or more layers allows an unlimited qualification range.
"All" on table QW-452(b) means:
(1) less than 13 mm deposited weld metal regardless to the number of layers
(2) 13 mm and over deposited weld metal with max. 2 layers
Regards - Juergen
Thanks, but , instead of writing "upto 12mm" , why ALL is written.
I only asking this, as code particularly specify the specific things/variables in any other section or subsection.
So, why not clearing/specific here.
Code can mentioned it as "upto 12mm" instead of writing ALL.
Thanks for replying and knowledge sharing.
Prasad Rode
Thanks.
