Hi, I am working on an air compr
I am working on an air compressor inter-stage cooler. The cooler is S&T type with TEMA type BEW . Air on the shell side is cooled with cooling water on the tube side.Air contain water content which upon cooling from 160 deg.C to 45 deg C. condenses. Air enters the shell side from the top of rear head and leaves the shell from the top side of front head. A liquid outlet is provided at the bottom of shell. I have attached a sketch in an effort to give some clarity to my query. Now, the challenge is to separate the water content from air before it leaves the cooler and is further compressed in the compressor.
I would request the experts to please advise how the water content can be removed. It should be noted that the air moves with a velocity of 12 m/sec and I'm afraid the air will sweep out the moisture(water). Certainly, one way could be installing a filter downstream of this cooler, before it enters the 2nd stage compressor. but I am looking for any solution within the cooler. Can installing a longitudinal perforated plate below the bundle and 2) Providing space(compartment) for liquid separation at the shell bottom below the bundle help? I would appreciate if anyone could advise any practical solutions.
Process Parameters:
Shell Side Fluid: Air
Shell side mass flow: 54095 kg/hr
Moisture (water) content in air: 662 kg/hr. (0.012 mass fraction of total air flow)
Shell side inlet pressure/temp. : 3.7 kg/cm2.g/ 160 deg.C
Shell side outlet pressure/temp. : 3.0 kg/cm2.g/ 45 deg.C
Tube side fluid: Cooling Water
Tube side inlet pressure/temp. : 3.5 kg/cm2.g/ 33 deg.C
Tube side outlet pressure/temp. : 3.0 kg/cm2.g/ 42 deg.C
Bilal
Process Parameters:
Bilal
RE: Hi, I am working on an air compr
https://en.wikipedia.org/wiki/Vapor%E2%80%93liquid...
Typically, for a regular wiremesh type separator, a Souder- Brown K value of 0.35fps (or 0.1035m/sec in SI units) is usual. In this case, since only coarse separation is required, a 100% exceedence may be okay ? - see also Perry Chem Engg Handbook, 7th edition, fig 14-124 and narrative, which indicates a superficial velocity of up to 4m/sec may be tolerated for vertical upflow of gas / mesh in horizontal plane for air /water systems with low liquid loading. Also talk to York to see if they would suggest an upper limit for the K value for coarse separation.
Using a max superficial velocity limit of 4m/sec (which corresponds to K = 0.7fps roughly), I get a 1200mm dia exit nozzle. Else an external wiremesh KOD or some kind of external cyclonic separator may be required.
