Pipe Fittings K Factors for 56" Pipe
I am looking for a standard table from IPC/UPC/ASHRAE/ANSI/ASME etc for pipe fittings k-factors, for larger pipes like till 56" (carbon steel with cement lining) I have reference for equivalent fitting method but I need K-factors for pipe fittings/valves for pipes as large as 56" or larger even
kindly help anyway you can
RE: Pipe Fittings K Factors for 56" Pipe
First, get the K factors for every fitting in 48 inch dia with the correct inside diameter AND liner thickness AND liner material for your 56 inch fittings.
Repeat for the 60 (5 foot) and 72 inch (6 foot) diameter fittings.
If the 56 values are not consistent with the trend between all sizes (regardless of what source you are given), use a different source.
Katmar Software - AioFlo Pipe Hydraulics
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
