VB code - Select all drafting views on a sheet
I need to create a journal that will select all of the views on a sheet and make all visible lines solid and .025 thick, and all hidden lines dashed and .013 thick. I cant seem to figure out how to even select all the views. lol
Keep in mind, a sheet may have two views, three views even a dozen views on a single sheet.
Manually the best way I see it done is to just go to Menu - Edit - Settings. Change type filter to "View" and then select all. When I record this action however, it records each view being selected.
