Have you used Concrete Hardeners
My area of expertise is in bridges and other transportation structures, however I was recently tasked with the detailed design for a potable water pump station. I have never even heard of concrete hardeners before as they are not used in bridge construction as far as I am aware. The architect wants to spec a hardener for the floor slab of our pump station. Just wondering what your guys' experience is with concrete hardeners? Do you regularly use them? Do they really provide a benefit? Any specific products you would recommend?
RE: Have you used Concrete Hardeners
The applicator has to be skilled; there is a chance of messing up and ending up with a slab that delaminates from improper timing or over-trowelling.
Dik
Besides the two types of hardeners dik mentioned (which generally are shake-on types) there is also a more moderate system referred to as a "liquid penetrating hardener" such as this one:
Link to SealHard
You could also consider an epoxy coating on the floor.
Jayrod: a properly placed hardened slab is much better than a kazillion MPa conc slab with the added shrinkage, noted by Ron.
Dik
Although what you say is quite true. The fact that you had to specifically note properly placed is why I try to avoid it unless absolutely necessary. Especially given the description of intended final use. It seems an overall waste of money and effort.
Dik
