Failure of Steel Plate
Hi there,
I am trying to check whether the 1/4" plate shown in the attached drawing will fail when a 6T point load is applied in the middle (in bending) and near the supports (in shear). How would I go about analysing this? I was first thinking to analyse the plate as a simply supported beam but the plate is restrained on all 4 sides. Any help would be appreciated.
RE: Failure of Steel Plate
If I'm remembering correctly this is covered directly in Roark's.
The span in one direction is larger than the other direction, you can treat the plate as beam. The ratio of span to the plate thickness is 78 and therefore you can ignore the membrane force in the plate.
Also, please note point load is just a theoretical concept, the real dimension of the load foot print should be considered in your case.
Do you mean 12,000 lbs? Using that, I ran it myself......and I came out with it being greatly overstressed (assuming we are talking about A36 plate here). And that is with the supports being completely fixed as well. (Which isn't going to occur with it sitting on some beams.) Pinned would probably be more accurate.
Running alternate thicknesses (with pinned supports), I came out with 5/8" thick being borderline on stress (about 27 ksi max.) deflection was ok (about 0.12"; at 5/8" thick). These numbers are with NO impact factor by the way.
