Stain from Fireproofing crack
Hi all,
During PFP vessel survey we found this stained from cracking on PFP and PEC test over the cracking PFP and nearest section found no corrosion under fireproof.
Anyone experience this problem, please advise. for me it look like some grease but i'm not sure this is from fireproof build process or what??
http://files.engineering.com/getfile.aspx?folder=7...
http://files.engineering.com/getfile.aspx?folder=0...
