Hand crank right angle drive
I need to design some adjustable guides that will move on a lead screw with a hand crank. The problem I have is I don't have enough room to come straight out of the lead screw with a hand wheel. I need it to be 90 deg from the lead screw. I can't seem to find a right angle drive for a hand wheel. All I find are for motors which I won't be anywhere near the rpm. Any suggestions on where to source?
RE: Hand crank right angle drive
Bevel gear boxes are out there. How about a low ratio worm drive?
JHG
I am assuming a 1:1 gear ratio. Is this correct? How strong does this mechanism need to be? Are you lifting a truck or lifting a microscope stage?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
http://www.wmberg.com/products/assembly/gear-boxes
http://www.pic-design.com/gear-assemblies.html
McMaster.com Right-Angle Gear Boxes
http://www.screw-jack.com/mini-worm-gear-linear-ac...
Same site has miter gear boxes, ie 1:1 ratio too.
