Question about eblock Ansys
Ansys reference materials list the eblock command as having the following format
EBLOCK,NUM_NODES, SOLKEY
then the formatted element list
Even showing examples with this format
But the input file exported from workbench has the following format
EBLOCK,NUM_NODES, SOLKEY, X
Where "X" is some number. What is this number? The attached graphic shows the Ansys command reference on the left and my input file on right.
RE: Question about eblock Ansys
Hi Chris,
My exported input file (v17.1) looks a bit different:
CODE --> Ansys
/wb,elem,start            !  set before creation of elements
/com,*********** Elements for Body 1 "13702-00011" ***********
et,1,187
eblock,19,solid,,12875
(19i9)
My 12875 appears to be the number of elements I have in Body 1.
Best regards,
Sze Kwan (Jason) Cheah
