Quickleg 90
Quickleg 90
Quickleg 90
Is the only purpose of a quickleg 90 ell to install a dummy leg in the spare socket? Unlike the bw cushion/target tee which still has an open portion to collect sand, silt, etc., the quickleg 90 is a tee but still only has a 90 degree pattern internally. So is the spare socket only for dummy leg installation or is there another purpose?
RE: Quickleg 90
I'm not familiar with the term so I had a search and still not clear what item you're talking about.
I think I know, but would like to be certain.
Do you mean the attached?
If not can you post a link / picture/ attachment please.
RE: Quickleg 90
Hi LittleInch,
A cushion tee is similar except it is a butt weld fitting used in erosive services whereas a quickleg 90 is a socket weld/threaded fitting. See the link below and scroll down to page 8.
http://www.bonneyforge.com/resources/FSFU.pdf
RE: Quickleg 90
Yes - dummy leg/pipe support.
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
RE: Quickleg 90
Thank you Latexman,
That was all that I could think they could possibly be used for, but before I started trying to tell my colleagues that, I wanted a second opinion.
RE: Quickleg 90
Strikes me that putting a dummy pipe in there is wholly bad idea as it will look like there should be flow out of the said pipe to anyone seeing it without knowing it is actually only internally an elbow....
Given these are not even a cushion tee type thing can't understand what's wrong with a normal elbow??
Never knowingly seen one, but you learn something every day...
RE: Quickleg 90
Yes, those dummy leg/pipe supports can be misleading in the field. You have to be on your toes not to get misled. I've seen some labeled like "Pipe Support Only" or similar.
Good luck,
Latexman
