CATIA V6 Macro - Insert new 3DPart under Product
Hi
I want to write a macro using VB.NET or VBA to insert a new 3DPart or 3DShape under a product. I read V6 Automation Help document but i don't see it. I also used record but CATIA can't record that action. I followed this example to write my code Instantiating Product Representation Reference but it doesn't work. Here is my code:
CODE --> VB.NET
Public Sub Macro_Chenbulong()
        Dim ActiveEditor As Editor
        ActiveEditor = CATIA.ActiveEditor
        Dim oProductService As PLMProductService
        oProductService = ActiveEditor.GetService("PLMProductService")
        Dim oVPMRootOccOnRoot As VPMRootOccurrence
        oVPMRootOccOnRoot = oProductService.RootOccurrence
        Dim oVPMRefOnRoot As VPMReference
        oVPMRefOnRoot = oVPMRootOccOnRoot.ReferenceRootOccurrenceOf
        CATIA.GetSessionService("PLMPropagateService").Save()
        Dim My3DPartService As PLMNewService
        My3DPartService = CATIA.GetSessionService("PLMNewService")
        Dim MyEditor3DShape As Editor
        My3DPartService.PLMCreate("3DPart", MyEditor3DShape)
        Dim MyEditor As Part
        MyEditor = MyEditor3DShape.ActiveObject
        Dim MyVPMRepRef As VPMRepReference
        MyVPMRepRef = MyEditor.Parent
        Dim MyRootRef As VPMReference
        MyRootRef = MyVPMRepRef.Father
        Dim cListInstances As VPMInstances
        cListInstances = oVPMRefOnRoot.Instances
        Dim oNewProdInst As VPMInstance
        cListInstances.Add(MyRootRef, oNewProdInst)
    End Sub
When i debug, cListInstances error: nothing
What can I do to fix that?
RE: CATIA V6 Macro - Insert new 3DPart under Product
I might be wrong but what the hell: are you trying to add a VPMRepInstance (the instance of 3DPart) of a VPMRepReference (the actual 3DPart) in a collection of VPMInstances? Isn't that wrong? I imagine you should call the VPMRepInstances collection instead of VPMInstances.
Hope it helps,
Calin
I am not sure. This is example in document
Sub Add( VPMReference iProductReference,
VPMInstance oProductInstance)
Creates a new child PLM Product Instance.
This example shows you how to instantiate a PLM Product Reference (oProdRefToBeInstantiated), to insert the new instance below another given PLM Product Reference (oProdRefAsParent)
CODE --> VB.NET
Dim  oProdRefAsParent  As VPMReference
   Dim  oProdRefToBeInstantiated  As VPMReference
   Set  cListInstances = oProdRefAsParent.Instances
   cListInstances.Add oProdRefToBeInstantiated,oNewProdInst
i Think problem is when I created a new 3D Part, active window changed
