Vacuum distilation Column under external pressure made in flanged sections
I have a SS304 distillation column that's supposed to operate under a full vacuum and is fabricated in flanged sections 1600 mm dia each 3500 mm in length and 6 mm wall thickness.
The sections are flanged to each other by bolted flanges 1800 mm dia and 40 mm thick.
My question is, can I take credit for the flanges themselves as stiffening rings (assuming their moment of inertia is high enough which I think it is in this case) in which case the max unsupported length for a buckling calculation would become the section length of 3500 mm.
Of course, this calculation will be verified by a PE later but I am only trying to get a rough estimate of suitability for now.
RE: Vacuum distilation Column under external pressure made in flanged sections
At a quick read, there do not appear to be any particular MOI requirements for these flanges.
Mike
