Error Abaqus 6.14 - error code 1073741515. Any simulations running.
Hi Everyone, I am having a error to any simulation with my Abaqus 6.14, Someone can help me!! I try to rename a fields into the simulia folder, because see that solution in the web, but was not solved. Please some tip to understand better what can be?
The error showed is:
The executable pre.exe aborted with system error code 1073741515. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
