stresses in global x direction within shell element
I'm trying to deduce the stresses in my shell element S4R in the global x-direction.
I requested S11 and S22 in history output but there are large differences for the positive (upper surface) and
negative (bottom surface). Can anyone explain what the correct procedure is?
RE: stresses in global x direction within shell element
In postprocessing you can transform the field output in another coordinate system. Search for "transform" in the A/CAE manual.
Afterwards you can create xy-data based on that new field.
