Section Labels
Section Labels
I have tried to make some sections in drawing and I used JIS standard first for section lines. Now I have changed the standard for the section lines but incrementation list for secton labels was not updated. Now if i try to make a new section, the letter in the section label is the next letter from the incrementation list. For example is "T" but I need "F". How can I update this list for incrementation ?
Thanks in adv.
Thanks in adv.
RE: Section Labels
In Drafting Preferences toolbar you can find "Section Line Display Preferences" button and iside after you select sectioning line you can edit letter (in bottom of dialog after you check Display Label).
By
cdantim
