POWER PLANT FIRE PROTECTION SYSTEM
what is the proposed fire protection system to sea port power plant
RE: POWER PLANT FIRE PROTECTION SYSTEM
Water.
Really need a bit more info my friend.. smile
Check NFPA 850 to see if it is endorsed.
Do you mean a floating thermal power plant on a floating paltform/barge, or ship or a plant on the shore or harbor?.
The risk is the same. So same NFPA 850 rules apply.
In a floatng barge, its similar.
But if it is on a ship with engines you have to add ship protection.
thank you very much,
its a power station feed sea port.
Also is Factory Mutual Data Sheet 7-79 on power plants.
