Extracting NX model info
Is it possible to export NX9 model information to a spreadsheet (or xml file)? We need info relating to Cylindrical Faces and Planar Faces (i.e. Axis vector / Normal vector Direction Cosines, Hole Center Coordinate value, Feature Type (Cyl or Planar Face)). What API should I use? Also need to export any attributes associated with the feature. I don't mind exporting ALL data associated with the 3D model to a spreadsheet and then searching the spreadsheet for relevant information.
Thank you.
Thank you.
RE: Extracting NX model info
Select Face or feature of which you need information. You will get a text file with all the information. You can save this text file and import to Excel using "from text" option in "data" tab.
Ranjith P R
Automotive Seatings
