interaction problem!!!
On an abaqus interface I have two solids a foam and a plane, I will apply on the foam a compression so that it compresses on the interface of the plane, the problem I had was that when i applicate the compression the foam passes through the plane.
any solution please!!!
RE: interaction problem!!!
