Shear Force
Shear Force
Shear Force
Hey Fellows, i have a question,
incase i do not have any in-plane shear in the slab due to wind or any source then what is the minimum shear i need to consider inorder to calculate in place shear ties??
Thanks a million in advance.
RE: Shear Force
If there's truly no in plane shear demand (wind, seismic, stability), I don't believe that you need to satisfy a minimum requirement.
RE: Shear Force
There is a minimum lateral force, from asce 7-10. If this is what you are looking for, check out (asce 7-10 Ch. 1.4.3)
