Reverse plane direction Vb.net
I want to change the direction of an offset plane, basically I want to make the reverse option. Any Idea of how to do it?
Tiago Figueiredo
Tooling Engineer
RE: Reverse plane direction Vb.net
Method on HybridShapeFactory is called
AddNewInverse
From documentation:
Func AddNewInverse( Reference Element,
long Inverse) As HybridShapeInverse
Creates a new Inverse within the current body.
Parameters:
iElement
The objet to inverse
iInverse
the type of inversion (see CATGSMOrientation.h) 1 for no inversion -1 for inversion
oInv
The inverted object
Hope it helps,
Calin
yes it helped. :)
I have changed the value to -Value. and it worked.
Tiago Figueiredo
Tooling Engineer
So I guess you didn't want to change the orientation but the direction :)))
Good one :))
Calin
exactly
Tiago Figueiredo
Tooling Engineer
changing the value is one thing, the other thing would have been to use the HybridShapePlaneOffset.Orientation = -1 property
Eric N.
Hummm nice.
Tiago Figueiredo
Tooling Engineer
