volumetric expansion of 150 psi petroleum hose
I am trying to figure out the volumetric expansion of a 4" 150 psi petroleum hose per psi on water. I am working on uncertainties in our liquid calibration lab and need to take into account the 15 ft hose for the connecting volume in our calibration loop. Can anyone help?
RE: volumetric expansion of 150 psi petroleum hose
You need to find the elastic modulus of your particular pipe.
Ask the vendor / search out a data sheet.
Or test a section.
Why don't you just pressure up the hose to 150psig with water and measure how much water it took to do it.
Reaction to change doesn't stop it smile
