How to get 356-T6 aluminum back to weak state?
Some of the castings we get from the foundry aren't quite as straight as I'd like. I'd like to pull those out, weaken them, hammer them straighter and then re-heat to T6 state. What do I need to do to get the part back to the weak (as cast) state?
RE: How to get 356-T6 aluminum back to weak state?
around 300-400˚C (575-750˚F).
Suggest review of AMS2771 Rev E Heat Treatment of Aluminum Alloy Castings
Rationale [for Rev E]...
AMS2771E results from a limited scope ballot to clarify when refrigeration may be used for retention of the AQ condition or to facilitate straightening (3.2.10).
Take the -T6 Casting: solution HT and quench it; immediately freeze [0F] after quenching; remove castings from cold storage [one-at-a-time] for straightening while in AQ [W] Temper; then age HT straightened castings [back] to -T6 temper.
Regards, Wil Taylor
o Trust - But Verify!
If you foresee this being an ongoing issue, I would recommend looking into what is actually causing the distortion. Mechanical straightening addresses a symptom rather than the root cause. If the distortion is created during the heat treatment process, then look at modifying your heat treat process. If the distortion is created during solidification of the casting, then look at modifying your tooling and/or design of the casting itself. Changes to your heat treat process should not cost much. Changes to your tooling or casting design will involve some cost depending how extensive they are. If the casting is being produced in any significant quantity, then the cost for these changes would likely be offset by eliminating the manual straightening procedure.
Here is a helpful article from the AFS: http://www.afsinc.org/about/content.cfm?ItemNumber...
The most significant residual stress will probably due to the quenching process involved in solution treatment and if this is the cause of distortion you may struggle.
What are they like as raw castings before solution treatment?
It may be worth looking at quenching into water at between 70 and 80 degC to reduce distortion.
That's a good point on the possible distortion after initial straightening and then after the subsequent heat treating. I'll try to get a handle on that.
As I mentioned in my original post, best time to straighten [or stretch/cold-work] aluminum alloys [including castings] is in the post-quench unstable 'W' temper. In this case the major distortion potential at the time of quench is BEFORE the straightening! After straightening in W temper [work fast], then a low temperature bake is required to [re] attain -T6 temper Potential for warpage in the low-temp [long-bake] is minimal.**
**NOTE: this is not the only path to -T6, but is fastest. However, it might make sense to allow natural aging to -T4 to RT stabilize the casting 'as straightened'... then bake-age to -T6.
Regards, Wil Taylor
