Straightness tolerance
Dear all ;
According to ASME B31.3 what is the tolerance of piping straightness for a welded c.s. pipeline 1 km long
Thanks in advance
Thanks in advance
RE: Straightness tolerance
Two points make a straight line.
Reaction to change doesn't stop it
Some locations and pipes will accommodate significant horizontal shifts and zig zags, others will be laser line straight.
Not everything is written in codes....
If nothing then it becomes a judgement call. As said, for a line of that length, I would place a maximum of 1m away from a notional dead straight line or a maximum of 1 degree at any one point in terms of deflection.
What have you got?
do you have any pictures you can share?
you give us very little to go on here.
With my respect to all of you
Loss of support is another problem. Check the stresses in the line, using the deflected shape. Do the lines need to be continuously drained.
