Welded wire fabric reinforcing in a stem wall
Hi all,
I have a client that wants to use a 4.5" stem wall (non load bearing). Does anyone ever use WWF as reinforcing in a foundation element? Would you ever use WWF in a stem wall? To me, that sounds like it's probably not a good idea for long term use in a thin stem wall.
Thanks!
Thanks!
RE: Welded wire fabric reinforcing in a stem wall
In load bearing and shear wall applications, my concerns would be:
- performance of any anchors used for shear transfer or hold down and;
- the contractors ability to get good consolidation in such tight form work without resorting to formwork vibration etc.
Other than that, I've no problem with WWM if it works by the numbers.
