Helium inflatable pipe plug material?
I require an inflatable pipe plug for temporary sealing a 1m diameter pipe pressurised with 1 bar Helium at about 350 deg C or lower.  Can someone point me in the right direction for a possible supplier or recommend some materials to use.  Permeability tables of Helium at these temperatures for NRHB, Silicone, PVF etc will help.  What should the inflatable length be to ensure a proper seal?
RE: Helium inflatable pipe plug material?
You can buy inflatable test plugs as a stock item.
We have been using these type of plugs/pipe stoppers from various suppliers for many years, but our regular suppliers do not cater for Helium nor the high temperatures.  A lower temperature may be possible in the sealing region but will require active cooling.
