Virtual Components
Virtual Components
I have just encountered a virtual component in a design I am trying to fix. I did not realize that when you insert new parts, they are virtual components. I always rename them immediately. I am trying to wrap my head around this.
Has anyone out there methodically used this feature? Any thoughts? Any issues?
JHG
RE: Virtual Components
Virtual components have been in SolidWorks since SolidWorks 2008.
Anna Wood
SW2015 SP5, Windows 7 x64
I have been generating virtual components and converting them to real components. I had no idea I was doing this. I am not having a problem with them. Virtual components might be a work-around for our PDM. When I create new components, I attach drawings to them immediately, which may rule out virtual components.
I was curious about how people use this feature.
JHG
I also use them extensively for concept assembly designs.
Thanks.
It has been a while since we have seen you. Welcome back!
JHG
Unfortunately, that is a default option in SWX. I didn't change my options though because when I use them now im usually using them like a scratch pad and if I like what ive got, then I will save out to the network to keep it.
Jon
