Air spring failure-vertical cracks
Our heavy truck cab suspension air springs are failing with vertical cracks, as shown at attached photo.
Horizontal cracks are result of fatigue. However supplier hasn’t found root cause and solution yet. Fatigue test is running again but failure can not be replicated at lab test.
We repeated ozone test with small air rubber specimen, similar issue can ne be replicated neither.
There is no rubbing.
I will be appreciated if you can share your comments.
RE: Air spring failure-vertical cracks
