Engineering standard for nylon screws?
Can someone point me to an engineering standard for nylon screws?
RE: Engineering standard for nylon screws?
A-A-55623 COMMERCIAL ITEM DESCRIPTION SCREW, MACHINE, 82° AND 100°, FLAT COUNTERSUNK HEAD, SLOTTED, PLASTIC (NYLON), UNC-2A AND UNF-2A
A-A-55624 COMMERCIAL ITEM DESCRIPTION SCREW, MACHINE, PAN HEAD, SLOTTED, PLASTIC (NYLON), UNC-2A
Regards, Wil Taylor
o Trust - But Verify!
B.E.
You are judged not by what you know, but by what you can do.
No one has asked this yet.
What do you need the fasteners for? Why must they comply with a standard?
JHG
Tbuelna-I've used them in applications that are near sensitive electronics, where conduction would be problematic. I've also used them as frangible fasteners.
drawoh-See above for typical uses. It's typical of my company to use standard parts for a system that is entering production, as I believe is the case with most aerospace.
http://www.tiodize.com/composites/ [links not working?]
Regards, Wil Taylor
