260 Cartridge Brass - Hard vs Half Hard
My supplier is out of 260 Cartridge Brass - Hard Temper which is being used to manufacture flat washers. Can somebody advise me, if the half hard temper which is readily available be used as a replacement?
Thanks in advance!
Thanks in advance!
RE: 260 Cartridge Brass - Hard vs Half Hard
In order to get an intelligent answer to that question, you would have to describe the loads the washer is subject to.
a softer washer may or may not be adequate.
B.E.
You are judged not by what you know, but by what you can do.
Apparently the link I added did not come through I will try again.
http://www.vvmetalli.eu/prodotti/ottone/specifica_...
BE CAUTIOUS: bearing [crushing] strength of a washer is an important mechanical feature. IF understrength [low yield/crush], then joint will likely loosen in-service!
Per MIL-HDBK-698, Table XXI...
Alloy 360 [KSI]...
Strain temper UTS TYS %El
H [<0.187 thick] 80 45 -ns-
1/2H [<0.50 thick] 57 25 7%
Regards, Wil Taylor
o Trust - But Verify!
